C1 RADIATOR SUPPORT - NCRS Discussion Boards
C1 RADIATOR SUPPORT
  • Joe D.
    • April 30, 2002
    • 382
    C1 RADIATOR SUPPORT
    I need a radiator support for a early 61 (60's type top tank). Should I look around for a used one or are the repros the way to go? I want to keep the car as original as possible. I am not sure if I will be able to find an original.Thanks, Joe DeLuca #37862
  • Ted L.
    • May 31, 1999
    • 101
    Re: C1 RADIATOR SUPPORT
    Joe,
    I was faced with the same dilemma. The original was rusted very badly where the carriage bolts go through the bottom so I opted for a repro. As repros go, the one I got from CC wasn't too bad, I think I had to file the corners of the top cross bar because of an interference but other than that it works and looks fine.
    Ted #32350
    • Bill B.
      • September 30, 2002
      • 351
      Joe, I had same type problem and solved by buying another partly rusted 59 or 60 support off ebay a couple of years ago. My 58 drain plug hole is round on the right side and the support I bought was elongated on the right. The carriage area support was rusted badly and so on. I cutout/traded/welded in sections, welded my front bracing and attachments on the newer support, cutout the elongated drain section and made a circle section and moved to the left side, welded in a solid section where I removed the drain hole, and shaved off the newer support lower carriage bolt area and welded same section in from my old 58 support. When finished, I had a perfect looking 58 original support. Think I have $35 invested and I had a terrific time doing it. Worked for me--maybe I am cheap.
      • Bill B.
        • 351
        I got my lefts and rights mixed up but you get the idea. It was lots of pure enjoyment. Probably a lot easier to buy a repo.
