I have had to replace my 250HP 1965 intake manifold and carburetor with the correct units. The Holley that was installed did not have a vacuum line running from the rear of the carburetor on the right side down along the exhaust manifold. (Parallel to the thermostat heat riser tube) The 3697 WCFB has a nipple outlet at the top right rear to attach a vacuum hose. What is the purpose of this vacuum line?
Thanks Ray
Thanks Ray
