Does anyone know how the headlamp warning switches work? I know the wiring circuit. Activation of either or both switches causes the circuit to be completed and the dash light turns on. What is the mechanism in the switch that makes the switch close? Thanks.
Headlamp Warning Switch 1968-1972
Re: Headlamp Warning Switch 1968-1972
Tony,
There is a small push in waterproof switch on one side of the square switch that closes on contact with the headlight frame when headlights are in the closed position. The wiring harness plugs into one end of the square switch w/ a waterproof connection. The switch has a male threaded end which goes through a hole in the headlight mechanism and is held by a locknut. Hope you are not more confused now.- Top
In engineering parlance, switches are SPST NC (single pole, single throw & normally closed) wired in parallel. When HL buckets are down/closed, there is no contact to the switches, both switches are closed and complete a path to ground for the dash mounted warning lamp. When the HL buckets are up/open, there is switch contact, the switch open circuits, ceases to make contact to ground and when BOTH HL buckets are up/open, the dash warning light goes out. Switch construction technology is referred to as a 'microswitch'....- Top
Jack Humphrey, you sure seem to know your information, thanks for the info.
Could you please look at thread---need help locating '72 vette,
I responded to his search of a 72, and then I digressed to my flaming problem
of my own where my car caught on fire yesterday. Please read the story and please share your comments, what could cause such a fire, Thanks Big John
happyappy@peoplepc.com. Now my Mille Miglia red corvette will be known as
Flaming RED.....- Top
