1965 stencil location - NCRS Discussion Boards
  • Joe
    Where is the correct location for the frame stencil. I have checked my references and have come accross some discrepencies. Some state upside down on the passenger side frame rail towards the rear. Others depict it upside down on passenger frame rail but towards the front. Almost directly behind the second rocker panel support. Then the red crayon date to the rear. Which is correct? Also, color of the stencil is white and the date is red.
    Joe
  • Ray C.
    • June 30, 2001
    • 1132
    Re: 1965 stencil location
    The information and pictures that I have place the frame numbers just ahead of the rear kick-up on the passenger or right side. I have one picture where the shim marks are through the frame numbers. The numbers will be upside down because the frame started in to production upside down. The frame pull date is located on the right side between the two body mounts and will also be upside down. I believe that the frame pull date will be white, but I have read where other colors were used. I had a hard time securing a white lumber crayon, but finally found one.
    Hope this helps!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
