I am about to drop the body back on the chassis and hope that others have some suggestions as to the best way to do this. I used the 8 guys and a case of beer afterward method to take it off but I would like a more controlled method to put it back on. I sure would hate to mess up my new paint job. I'm not sure I want to do the nylon strap method with a hoist either. How about some kind of mechanical lift? I am sure lots of you have been through this and I would appreciate all suggestions
65 body drop
Re: 65 body drop
Nike
I Think the most controlled method is to find someone who has a two post lift, picking the body by the birdcage troughs, (rockers) is extremely stable although side to side adjustment while dropping the body can be a pain. Short of this the body lift strap and a picker capable of handling the weight is not a problem especially if it is a convertible. Pad the lift strap with moving pads if you are concerned and have a good guy on the cylinder release valve, have done my share by this method
Best of Luck
jer- Top
