C1 paint source - NCRS Discussion Boards
C1 paint source
  • kenneth bingener NCRS#38563
    C1 paint source
    Is there a supplier of ready to use spray can paint for the interior red (signet red I believe) for a 58? I need to paint the trunk cardboard and would like to get a close match. The trunk paint is original and the cardboard divider is incorrect and getting replaced. Thanks, Ken
    Re: C1 paint source
    Eckler's and Mid America used to offer a line of small shake 'n spray interior paints, if memory serves. But, nothing matches like 'spare' paint left over from your original restoration....
    Also, you might try doing a look-up at www.autocolorlibrary.com as the website goes WAY back with original blend codes for both interior and exterior colors that you can have blended once you know the appropriate blend code....
    • Mark Malone
      Re: C1 paint source
      Kenneth,
      If your car is driving then you should be able to get a DuPont or any major paint supplier to use a scanner to match the paint.
      They just hold the scanner over the original colour and the info is entered into their puter and it punches out the code.
      I used this method after I mixed the sample color and painted a small area on a piece of scrap metal.
      Some paint supply shops can then put it into a pressure pac can but if not you can buy a cheap sprayer at a hobby store and use that.
      Good Luck. Mark.
      My Vette Page!
      • Ray C.
        • June 30, 2001
        • 1132
        Re: C1 paint source
        I was having troubles matching the Dark Saddle areas of my 65 interior. The only code that PPG could offer was for the Light Saddle lacquer. A DuPont supplier custom blended the color using a part from the interior.
        Ray
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
