C3 427 Exhaust Manifolds - NCRS Discussion Boards
  • Art Ives
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C3 427 Exhaust Manifolds
    i had the same thread deterioration of the K-19 exhaust manifolds on my 67 L-71 when i was readying it for Duntov judging. I had the local machine shop use cast iron compatable stick welding rods to seal the 8 holes in the two manifolds. i then used helicoils in the 8 holes to restore threads so I could fasten the two smog pipes to the manifolds. Of course, you have to disable the smog pump itself.The K-19 setup, modified of course, made it thru the judging process without detection Good luck with your manifolds mike mccagh
