L-78 starting problems - HELP!!! - NCRS Discussion Boards
    Re: Sounds familiar
    Good luck and let us know how it comes out, Mike. By the way, BE CAREFUL with your spark check technique (extra wire). You'll see the '65 AIM gives a WARNING note under K-66 (TI) advising NOT to test spark on these cars by using 'traditional' coil lead to ground and/or plug wire to ground methods as you risk damaging the TI amplifier protective diode circuitry.
    Leaving the plug connected to the plug wire and grounding the plug body keeps the resistive load on the coil within design specs for the system. I'd hate to see you 'toast' your TI box while you do basic troubleshooting....
      Re: Sounds familiar
      • Floyd Dossey
        #18
        Re: Sounds familiar
        Mike If your TI or harness is suspect, contact Dave Fiedler at T.I. Specialty, he is the TI guru and a NCRS member, he should be able to help you. His phone number is (765) 962-4265 Good Luck Floyd
        • Floyd Dossey
          #19
          Re: Sounds familiar
