71 Manual tranny "TIN TAG" identification help. - NCRS Discussion Boards
  • Rick Church
    I have a 71 Vette with a 4-speed manual tranny. It has the "Tin Tag" still attached. I am having a hard time finding what the coded number means. It reads: "3981709WT"
    Any help figuring this out will be greatly appreciated!!
    Sincerely,
    Rick Church
    • 43193
    Re: 71 Manual tranny "TIN TAG" identification help
    Rick-----
    GM #3981709 is the GM part number for the wide ratio Muncie 4 speed transmission used in 1971 Corvettes. The "WT" suffix code is the broadcast code for this particular transmission.
    • Dave S.
      • August 31, 1992
      • 2918
      The tag on my 71 4 speed is 3981710WY. Is WY for a close ratio as this is a documented M21 car.
        • 43193
        Dave-----
        GM #3981710 is the part number for a 1971 wide ratio Muncie four speed. Both GM #3981709 and 3981710 are part numbers used for 1971 only. "WY" is the broadcast code for the 3981710 close ratio transmission.
        • Dave S.
          • August 31, 1992
          • 2918
          Thanks, Joe
