Can anyone tell me if 66 frames for cars that came with a rear sway bar are different from 66 frames for cars that did not come with a rear sway bar? My 66 small block car did not have a rear sway bar, but I notice two small holes of each rear frame rail with internal weld nuts inside the frame. The holes are 2" and 4.5" rearward from the 2nd to last rear cross member. Are these the holes where the sway bar bracket would be mounted? I can't tell exactly what these holes are for since the entire rear suspension is removed from my car and I'm just guessing that these holes were related to the sway bar. However, I thought non-sway bar cars didn't have the weld nuts on the inside of the frame and my frame clearly has them. For that matter, I didn't think non-sway bar cars had the holes at all. Can anyone clarify this point for me?
Gary
Gary
