1963 Sebring Silver paint code... present color - NCRS Discussion Boards
  • Peter McIntosh
    I have 1963 Sebring Silver split window. Can anybody give me the current pait codes that would allow me to get the BEST or Correct match for that color. I think the real color has some metalic in it.
    Peter
  • Jack Layton
    Re: 1963 Sebring Silver paint code... present colo
    The Sebring Silver was a metallic paint. DuPont 867-96417 Ditzler DDL 32312
    Did you check autocolorlibrary.com ? I think they show PPG paints? Anybody know if Sikkens paint has a match? I understand that the early paints used a small mettalic chip and that many newer metallic paints use a larger chip which has a different appearance than the original.
    I was told by a painter that Sikkens has a variety of metallic chip sizes and is considered by many to be the top quality paint manufacturer. Experienced painters want to give us their opinion ?
    • Karl #35089
      Sikkens is definately top shelf stuff. While I usually use other brands, I had one case recently where PPG could only offer an offset so I used Sikkens base/clear and obtained a great blend match. (this was '71 Ontario Orange) Certainly worth checking into.
      -Karl
      • Bill W.
        • March 1, 1980
        • 2000
        try dupont !
