62 Restoration questions - NCRS Discussion Boards
  • Ron Cwiklinski
    Trying to locate the proper tie rod ends for my 62. Mary Jo, Kanter, Paragon all have the grease fittings exiting near the threaded ends versus at a right angle to it. Any help in locating a proper banding kit/material for the rear springs and exhaust system hangers that would pass flight judging critera would be appreciated. Thanks in advance.
  • William C.
    • May 31, 1975
    • 6037
    Re: 62 Restoration questions
    I guess we need to define a little better the proper location of the grease fitting in an OEM location. The correct orientation is on a plane aligned horizontal to the ground through the centerline of the shaft with the grease fitting at about a 45 degree angle to the shaft. that sounds a lot like what you are describing as available from Mary Jo and others. Sounds correct per your description.
    Bill Clupper #618
    • Ron Cwiklinski
      Thanks Bill, all this time I was led to believe that the proper original location was at a right angle to the shaft.
      • Roy Braatz
        I buy many parts from Chevy organizations because many parts are original to Corvette. Try them for C1's
        www.nationalchevyassoc.com
