I've started taking the pistons out of my engine ('64 327/300). The cylinders look great. It was bored .030 over by a prior owner. My own measurements (spring gauge & micrometer) were taken at 90 degrees of each other, three different depths, 2 at each position for a total of 12 measurements in each cylinder. Takes forever. Anyway, the two cylinders I've measured ranged from a low of .028 over to a high of .031 over, with the majority of them right at .030. So I don't think I've got any significant wear. No ridge to speak of at the top of the cylinder - the pistons came out very easy. The tops of the pistons (TRW forged) have the 4 D-shaped indents and have carbon deposits on top, but the sides look great.
I had planned on putting in Keith Black Hypereutectic pistons at 9.6 compression, but now I am thinking about reusing the pistons I have. Any thoughts on that - pro or con? One side of me says put in new parts - I don't want to do this again - but the cheep in me says reuse them. Am I asking for trouble?
Speaking of trouble, I did mark all of the caps and connecting rods so they
wouldn't get mixed up, but I may have switched the nuts on a couple from one
side to the other. Is that a huge problem?
