70 A/C compressor painted as an assembly? - NCRS Discussion Boards
  • Lawrence Berte
    I'm in the process of rebuilding the A/C compressor on my 70 300HP, and would like to know if the compressor was painted as a complete unit. If so, was the triangular thick rear bracket (with shims), and the curved thick front bracket attached before painting having paint coverage on attaching bolts. Also was the pressure release valve installed before painting. Thanks, Lawrence Berte
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 70 A/C compressor painted as an assembly?
    Lawrence - From looking at a couple of A6 compressors, it appears that the compressor was painted with the pulley assembly in place; but the relief valve was either not installed or it was masked so it was not painted. The brackets where not part of the assembly when painted although they are painted. When you find shims on original cars, they are not painted but have the zinc plated finish. Hope this helps. Pete
    • William C.
      • May 31, 1975
      • 6037
      They also covered the terminals where the clutch wiring is connected
      Bill Clupper #618
      • David D.
        • 330
        Larry, Take a look at eBay item #2408120552, off a 1974 Corvette. I believe it still has it's original paint. FWIW. Dave
        • Juliet P.
          • June 30, 1999
          • 349
          I have a webpage on the '70 Registry in the Photographic Library with a bunch of detailed photographs of the original unrestored AC compressor from my B18 build date 1970 350/300. The AC compressor was painted after assembly, but before installation. The brackets appear to have been dip painted as evidenced by the runs in the paint. The valve on the side is definately painted black. The valve on the rear has no evidence of paint (or a masking line that I can distinguish clearly). The masking lines from the electrical connector are also shown on the website.
          Also, please consider sending me your vehicle specifications for the '70 Registry. I'm trying to track down as many corvettes as possible to gather color and option statistics. You can choose to have your vehicle info published online or remain in the offline only database. Thanks, ~Juliet
          1970 Corvette Registry
          2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
          1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
          1965 Coupe (Greg's project No Flight)
          Gone but not forgotten:
          1987 Yellow Convertible 199k mi.
          2002 Yellow Convertible 100k mi.
          2007 Atomic Orange Coupe 140k mi. RIP flood 2015
          2007 Lemans Blue 6-Spd Coupe 34k mi.
          • Lawrence Berte
            Thanks for all the great info! Lawrence Berte
