1979 Exhaust Manifold Heat Stove - NCRS Discussion Boards
  • Paul L.
    • November 1, 2002
    • 1414
    Is this part (with mounting bolts) still available from GM?
    Re: 1979 Exhaust Manifold Heat Stove
    Paul------
    Two different choke kits were used for 1979 Corvette carburetors, depending upon specific application. However, both are GM-discontinued.
    • Paul L.
      • November 1, 2002
      • 1414
      Thanks Joe. I will check the salvage yards.
      • Paul L.
        • November 1, 2002
        • 1414
        Joe,
        I cannot seem to locate that part. Here is a pic. Any hints as to sources?
          Paul-----
          I thought that you were referring to the choke assembly mounted on the carburetor. However, based upon the picture, you're actually talking about the carburetor air heat assembly. This is a 2-part assembly consisting of a plate and a cover. Both the cover, GM #367135, and the plate, GM #3946832, are GM-discontinued. The connecting elbow, GM #372586, is also discontinued. You can still obtain the duct, GM #1260631.
          I don't know of a source for these parts. However, I think that the same parts were used on other Chevrolet models, particularly trucks of the period, so a used source might work.
          • Paul L.
            • November 1, 2002
            • 1414
            Thanks again Joe. Yes it is the driver's side heat stove I am referring to. I thought it might be GM rather than Corvette so I will keep looking at 350cid applications.
