C3 1968 headlight issues .. HELP - NCRS Discussion Boards
  • Dale P.
    • September 30, 1995
    • 248
    Getting car ready for spring...
    Started the engine
    Pulled headlight switch inside after it got to a nice idle
    Headlights came on but did not open
    Shut car off, removed top vacuum hose to headlight relay valve...headlight doors opened up
    Put hose back on, started car....headlights went down.
    Thought it might be with headlight switch, had my wife hold thumb over top vacuum line while the motor was running and had plenty of vacuum
    Pulled headlight switch inside and she felt no vacuum, which is exactly how the system is supposed to work, so thought maybe there was dirt in switch...hooked everything back up and....same thing, headlights will not open.
    Any suggestions??????
