Interior color - NCRS Discussion Boards
Interior color
  • Ole Fretheim
    Interior color
  • Robert C.
    • December 1, 1993
    • 1153
    Re: Both 411 &414 are very similar. *NM*
    • Wayne W.
      • April 30, 1982
      • 3605
      Re: Both 411 &414 are very similar (Maybe)
      As I usually say with a 68 anything goes. In general 414 is somewhat, but not exactly the same color as the 69s, but 411 is another story. You will find that 411 could be more than one color, maybe many colors in 68. Usually when you come across a 411 blue interior especailly early serial numbers they will be marked with " SAMPLE or PILOT " and the color, material, and construction will vary greatly. Many that are marked 411 may even actually be 414 or what was currently masqurading as 414 at the time. In general 411 was darker and may range from dark royal blue to almost midnight blue. Usually on the earlier cars the trim pieces will be soft vinyl, hand made, and glued to the backing. I also use the term "early" guardedly because I have seen PILOT JOB`s on serial numbers as high as 3600. So the answer is that no one is going to know positively for sure, except you, what was on it. That is if you still have the original to see.
