C2 rear end case cover part number - NCRS Discussion Boards
  • Larry S.
    • August 31, 2000
    • 356
    Hello folks its been a while since I have needed your help.I own a 1966 corvette and have a question on what should the correct rear end case cover's part number should be.My car has a build date of October 28th of 1965
    I was told my cover should be 387135 with no date coding punched into it by the filler plug,So now I am calling around trying to find a correct rear cover and then I was told by a used part supplier that NO your rear case cover should be a 3830303
    The cover thats on the car now is a 464910 and I had a broken cover that came with the car that the last owner snapped installing the rear spring,I threw it out and never kept it because I fealt it was un-reparable
    When I first bought the car I used to think numbers ? what numbers are they talking about? So now I am learning little by little what numbers are all about.Quite exspencively when your looking for the correct number I may add.
    As alwaays thanks in advance for your help
    thanks Larry
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: C2 rear end case cover part number
    Larry -- you want an undated 3871375 rear carrier cover. The "303" was used on C2s up to sometime in '65 (my # 014xx has one, but with the "375" type filler plug threads), and my # 235xx has the "375".
    • Larry S.
      • August 31, 2000
      • 356
      Wayne do you know when the cut off date was on the covers My car with a build date of oct 65 seems to be an earley car.I am missing what your saying with your vin hear are your cars 65'S or 66'S
      Thank you for the input.And Your comments have at least confirmed to me that there was a earley case cover and then a later style
      • Craig S.
        • June 30, 1997
        • 2471
        My 67 (May 11 build) has an undated 1375 cover, unfortunatly one ear was cracked and I now have a 68 date cover to replace. I don't think they judge the casting dates or casting numbers on the rear end, but, who knows later on, and I am always trying to replace with correct parts...Craig
        • Wayne M.
          • March 1, 1980
          • 6414
          Larry -- My cars are both 1965's. The early 4:11 differential is coded / dated AP 9 17 64, on car 014xx, (trim tag D6 -- Nov 6, 1964) and this one has the hybrid "303" cover with the coarse-thread plug. I wish I knew when the cut-off date was -- I suspect it was soon after my unit, and that most '65s had the "375" cover. BTW, the '65 Tech Manual makes no reference to a "303" cover on an early '65, so I'd like confirmation by others.
          Your early '66 should have the "375" un-dated cover for sure.
          Craig is correct in that the cover # and dates on the CARRIER (not the cover) are not (yet) judged.
          • Larry S.
            • August 31, 2000
            • 356
            Thank You! for your input.Althought not judged I want it to be factory correct.I am removing a 411 read end to go to a smaller set 336 and want this to be the last time I have the rear suspention portion of the car out untill I do the next restoration with my grandchildren in 40 years or so.So I am trying to correct the rear case cover with the correct one even if it means I have to delay the installation of the rear untill I aquire the correct rear cover.
            Does anybody reconise what the cover I have on now is for?
              Larry-----
              The cover that you presently have installed, GM casting #464910, which is known as GM PART #464909, is the 1978-1979 PRODUCTION cover. It is also used for 1963-77 SERVICE and has been the only cover available from GM to SERVICE all 63-79 applications for over 20 years. This cover is drilled and tapped for 7/16-14 spring retainer plate bolts. Originally, this was done to accomodate the 2-1/2" wide springs used for 78-79. When this cover is used with an original 2-1/4" wide spring, used for all 63-77 Corvettes, special spacers must also be used. If your car is equipped with this cover and an original 2-1/4" wide spring, then you should find the spacers, front and rear, between the spring and the retainer bolts.
              The original covers were drilled and tapped for 9/16-12 spring retainer bolts and no spacers were used. If you convert to the earlier style cover, you will need to change the bolts to the 9/16-12 size. Originally, these were a special bolt with a longer-than-standard unthreaded shank. Those bolts have been discontinued for years, but standard configuration bolts can be used.
              Also, the spring retainer plate used with the 464910 cover and 7/16" bolts has smaller bolt holes in it than the cover used with the 9/16" bolt hole configuration. Otherwise, the plates are the same. You can enlarge the holes on your plate, if necessary, to accomodate the 9/16-12 bolts. The GM spring retainer plate for the 9/16" bolt holes is discontinued.
              • Craig S.
                • June 30, 1997
                • 2471
                Wayne - so is the 1375 judged on the cover? How about the date on the flange near the oil fill plug? I suppose I could look for one that has no date like my original 67...thx!...Craig
                • Larry S.
                  • August 31, 2000
                  • 356
                  Thamks Joe and all else for there input
                  Joe I have no spacers I had removed a trw fiberglass spring and replaced it with a reproduction metal spring I remember the metal one not fitting correct,I also had ordered reproduction bolts for when I installed my new correct spring,And the bolts would not fit they were too thick.I just figured the supplier sent me the wrong bolts.(I still have them)
                  What is the correct rear case cover I shold be shopping for 135 or the 303?
                  Thanks again every one
                    Larry-----
                    GM casting #3871375 is the one you need. It's, by far, the most common one, too. It was used from 1965 through 1977. So, there are lots of them out there.
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Sorry my response was fuzzy; but so is the description in the '65 Tech Manual -- you have to read it several times to figure out if they're talking about #s and dates on the cover or on the carrier.
                      #s and dates are not judged, probably based on difficulty of seeing them with the spare tire carrier, muffler and wheel blocking the view. And yes, I'd look around for an un-dated "375".
                      • Craig S.
                        • June 30, 1997
                        • 2471
                        Thx Wayne, there must be a few out there. I thought maybe my 67 just missed the cast date on the cover, but now I have learned something new...and will look for the right undated 375....thx!...Craig
                        • Larry S.
                          • August 31, 2000
                          • 356
                          A sincere THANK YOU AGAIN to all who helped.I have allready found a new rear case cover (undated)and it will be shipped on Wensday.
                          The wonders of the internet what did folks do prior to find information like this
