C2: 4SP Trans ID - NCRS Discussion Boards
C2: 4SP Trans ID
  • David Hicks
    C2: 4SP Trans ID
    OK,
    I have info on another 60's tran, but again, not the numbers I need to identify it. Can anyone tell me what "4 SPD TRANSMISSION--IMPUT SHAFT 10 SPLINE--OUTPUT SHAFT 16 SPLINE--LOOKS LIKE A 1960----T10-IC W.G. DIV T10-7B 9-28-60 11-9-G2"
    all means. It looks like a 1960 4SPD Warner Gear trans, but how to tell which ID it would have.
    Re: C2: 4SP Trans ID
    David -
    The T10-1C main case was used from 11/60 thru '62, and the T10-7B extension housing was used from 1960 thru 1961; the combination of the two would only be seen on a 1961.
