Warning: Undefined array key 2157 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Advice on Painting 70 Frame. -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I am getting ready to do a frame-off restoration on the wife's 70 Convertible. I would like the durability of powder coating the frame, but what would the point deduction be for this? Or could I powder coat the frame and then paint over the powder coat?
I would stick to paint. I had my 165000 mile 70 frame dipped a redi strip. lightly sanded it put a good coat of dupont vari prime self etching primer and painted it with flattened dupont imron . it wont chip away when you tighten bolts with lock washers . brake fluid ,gas etc wont hurt it.it also wont stop bolts & screws from grounding wires to the frame. and touch up is only a brush stroke away. Bill
