Not sure if you remember my engine woes from a year ago today (that's too weird). I had the newly rebuilt 427/390 that had the awful squealing noise. Last year we got alot of help from John Hinckley, Gary Wylie and Jim Frakes, not to mention half of the ncrs on installing distributor and engine timing in general. At that time, the engine started right up. That was scary, but after 20 minutes of running, that horrible squealing occurred.
Well, I sent it back to the builder in Nebraska and we finally got it back in January. Just put it back into the car and the thing won't fire. We still have the copies of all the advice we received and have followed it to the letter. The engine runs ahead of the motor trying to start, but it just won't fire. What we did: Turned engine until both valves on #1 cylinder were closed and piston positioned at the top. At this time, marking on balancer lined up at zero (TDC). Dropped distributor in so rotor faced forward. With cap on and timing light connected to #1 wire, gently turned distributor until light came on. Filled carb front bowl with gas and gave it a try. No cigar. As always any assistance would be GREATLY appreciated. I'm at the end of my timing chain.
Thank you all.
Deb
Thank you all.
Deb
