Painting rear spring - NCRS Discussion Boards
  • David Z.
    • April 1, 2002
    • 181
    I currently have the spring out of the rear of my 65 coupe. Want to repaint it while it's out. I seem to recall seeing something about them being gray but don't know where I saw that. I couldn't find the info in the older judging guide(beige cover. Maybe I didn't dig deep enough.
    Could someone please point me to the correct information?
    Thanks!
    Dave Z
    Dave Zuberer
    Re: Painting rear spring
    Dave -
    Quanta (www.quantaproducts.com) has the rear leaf spring gray paint; they also have all the parts to rebuild the spring in a kit (paint, liners, center bolt, etc.), but I haven't seen their liners.
    • David Z.
      • April 1, 2002
      • 181
      Thanks John! Gray it is! Hope all is well with you.
      Dave Z
      Dave Zuberer
        • 11608
        Dave,
        It would be nice if Franz E. would chime in here. No one could answer this better than him.
        This may sound funny, but can you tell if your spring has ANY paint on it currently? Any sign of the original gray? If you look closely, you may see pain "dribbles" along the edge of the spring leaves. Then again, you may not, as in 1965 some were painted and some were not.
        The original paint (Ikonoclad) is gray, and available from suppliers such as Quanta. To maintain authenticity, use a coarse brush to apply it. Originally I believe it was applied just to the top surface (as installed) but most people usually paint both surfaces.
        Patrick
        • Gary B.
          • February 1, 1997
          • 6979
          Rear spring paint; questions remain
          Patrick,
          The GM enginering drawings for rear leaf springs in the 63-78 time span call out the following paint spec:
          APPLY 3783188 PRIMER (IONOKLAD 200 J OR EQUIVALENT) ON TENSION SIDES AND EDGES OF LEAVES, MIN COATING .0015
          Now, the question is, would GM allow suppliers to paint the entire leaf, i.e., all 4 surfaces; top, bottom plus both edges? I suspect they would since it exceeds the spec. You can imagine that it might take much more time to paint the tension side and the two edges than it would to dip the leaf and cover all surfaces. In my mind the jury is still out on whether paint covers 3 sides or all 4 of mid-year springs. I'm aware of Franz's opinion, but I'm not convinced that springs were unpainted nor am I convinced that only 3 sides were painted.
          Gary
            • 11608
            Re: Rear spring paint
            Gary,
            I saw an unpainted rear spring on a 1500 mile 1965 convertible two years ago. I crawled under the car and looked at it myself, because Franz and I had spent a considerable amount of time discussing this at dinner the previous evening. We discussed how the painting changed over the years, when it occurred, etc. I "may" even have a picture of the spring, but to find that....
            I recently took apart the spring of a 1972 coupe. FWIW, it definitely appeared to me that there was remnant on one surface of the spring only.
            I will not attempt to rephrase Franz's thoughts here, as I'll let him do that himself if he chooses. He has the advantage, however, of having been there. We do not. I'm waiting to look at more before I make my own definitive decision, but for now I am following his thoughts. I know you've done a lot of investigating into springs as well, and for that I respect your opinion.
            Patrick
            • Gary B.
              • February 1, 1997
              • 6979
              Rear spring paint
              Patrick,
              I also know of examples of NOS springs with the compression side left unpainted. I just don't know if all springs were like that, given multiple vendors and engineering changes over time. When I first started researching this paint issue, some claimed that all original springs received no paint whatsoever and that simply conflicts with the engineering specs on the original drawings, so I think that at least after some point in time, the paint spec must have come into play. I think it's likely that we'll never really know the complete history about the paint issue.
              For the spring on my 66, I've chosen to paint all sides, figuring it's one less part that can rust and I think painting all 4 surfaces is consistent with what the judges expect to see.
              Gary
              • Franz E.
                • March 1, 1997
                • 96
                • Craig S.
                  • June 30, 1997
                  • 2471
                  Patrick - I remember that conversation we had with Franz a dinner in Bloomington a few years ago....I have an original F41 from my 66 L72 I bought last year and it has paint only on the one side....Craig
                  • Jerry G.
                    • April 1, 1985
                    • 1022
                    I have a July 8th built car with F40 that had paint only on tension side.
                    • Jerry G.
                      • April 1, 1985
                      • 1022
                      Re: It July 8th ,1965 *NM*
                      • David Z.
                        • April 1, 2002
                        • 181
                        Franz
                        Thanks very much for the education! There was definitely some thick paint on the top of my spring but it looked also like all four sides had been painted somewhere along the line. No early owner history on this car so it's anyone's guess what may have been done to the spring along the ownership pathway.
                        Thanks again to all who responded! Neat discussion!
                        Dave Z
                        Dave Zuberer
