Gentlemen:
I am starting the reassembly of my 68 coupe with 4 speed manual transmission.
In preparation of mounting the transmission to the engine for reinstallation into the vehicle, I have the following questions to which I seem not to be able to find answers in the assembly manual and therefore need your help.
Do the bolts that attach the bellhousing to the engine (3/8 x 16 x1 1/4)require lockwashers? There are 6 bolts in total. What is the torque for the bolts?
What type of grease should I use on the throwout bearing, pilot bushing, and clutch throw-out fork?
I have white lithium grease or Kendall HiTemp wheel bearing grease. Which do you recommend?
Thank you as always for your input.
Kurt Bunting # 26406
