Can someone give me the specs for dwell angle (single point distributor) and timing for my 1960? I see in the service manuel that timing is 12 Degrees advanced and dwell is 28-32degrees. Are these numbers correct? is the timing 12 degrees btdc or after? My mechanic said 12 degrees seem wrong. He thought 4 degrees btdc was more appropriate for a small block chevy. Thanks!
Don
Don
