62 FI Fuel Leak - NCRS Discussion Boards
62 FI Fuel Leak
  • Todd Pollock
    62 FI Fuel Leak
    I am gathering fuel on the intake of my 62 and it appears to be coming from a weephole on the botton of the plate where the high pressure drive comes off the distributor into the FI unit. Is there a gasket at the end of the high pressure drive cable that can go bad. It is not a streaming leak, but it is constant and has gathered a good amount of fuel over the past couple weeks. It only leaks when under pressure, or at least when running and the for a while after shut down. Any advice on how to correct gladly welcome.
    Todd.
    Sorry my desriptions are so poor. Let me know if you need me to clarify.
  • William C.
    • May 31, 1975
    • 6037
    Re: 62 FI Fuel Leak
    I'd start by looking at the seal on the pump shaft. and/or replacing it if it has not been replaced recently. Generally a new pump shaft is also required as the seal generally has created a groove in the shaft before it starts leaking. Kits are available including shaft and seal to repair this.
    Bill Clupper #618
    • Mike E.
      • February 28, 1975
      • 5134
      Re: 62 FI Fuel Leak
      Bill is right on, as usual!
      • Dave S.
        • August 31, 1992
        • 2918
        Re: 62 FI Fuel Leak
        Bill,
        Mine is "weeping" a bit. Only enough to get the gas smell but no drips yet. Is that a normal condition????
        • William C.
          • May 31, 1975
          • 6037
          Re: 62 FI Fuel Leak
          No, "Normal" is no leakage at all thru that seal. I have seen "minor" leakage go to "catastrophic" in a very short period of time, so the seal is a good item to keep fresh every few years.
          Bill Clupper #618
          • Todd Pollock
            Re: 62 FI Fuel Leak
            Thanks for the help Bill, I will work on getting that seal, and soon!! Weird thing is that is doesnt leak much when driving, not that it makes it ok.
            Todd.
            • Dennis C.
              NCRS Past Judging Chairman
              • January 1, 1984
              • 2409
              Re: 62 FI Fuel Leak
              Clup's advice should be followed before you restart your engine. Fire and fiberglass are not a good mix.
              • Verle R.
                • March 1, 1989
                • 1163
                Re: 62 FI Fuel Leak
                I would not assume little or no leak when driving. Engine heat and air flow would serve to evaporate the gas rapidly so it would not accumulate. Gas vapor around a hot/running engine may not be a good combination.
                Verle
