courtesy lights - NCRS Discussion Boards
courtesy lights
  • john pickens
    courtesy lights
    My C2 appears to have had replacement of the wiring harnesses done sometime in the past. I noted early on that the drivers side courtesy light was not functioning-this required a simple rewiring. The problem which persists is no courtesy lights when rotating headlamp switch to far right position. Can't tell from wiring diagrams where the miswiring would be. Each light works normally when
    door is opened. Any thoughts?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: courtesy lights
    The door switches and the light switch simply ground the system. Sounds like there is a break somewhere in the wire or the switch is bad.
