C3 Coil Question - NCRS Discussion Boards
C3 Coil Question
  • don justham
    C3 Coil Question
    Hi. Just bought a 1970 Corvette with a 350/300 Engine. It had a special type coil on it and I want to put a normal coil back in it. Looked at all my manuals but I can't figure out how the coil is held in place on the engine. ANy chance someone could take a digital photo close-up of the coil mounted to the block? Really appreciate all the great help in this group.
    • 11608
    Re: C3 Coil Question
    Don,
    Take a look at the pictures of my 72 in the links below.
    Patrick
    Daftar dan mainkan slot gacor dengan RTP tertinggi hari ini. VIPTOTO, situs terpercaya untuk cuan besar dari slot online!
      Don-----
      The 1968-72 manifold-mounted coil bracket, GM #1970344, shown in Patrick's photos is GM discontinued. However, this same bracket was used on many other 1965-72 Chevrolets and you should be able to easily find one in a self-service salavge yard. Also, the part is reproduced and available relatively inexpensively. However, with originals so easy to come by, I'd seek one out.
