I'm having a problem with the brake lights on my 1964 Corvette Convertible (without the optional reverse lights). The two passenger side brake lights are not working. The problem only applies to the brake lights as the turn signal and running lights operate fine. When the brake pedal is depressed, only the two driver side brake lights come on.
I've checked the bulbs which are fine. I even switched the bulbs from the passenger side to the driver side with no change. I reversed the connectors at the switch under the brake pedal to see if there was a problem with the switch, no change. I checked the connections at the taillights which seem fine. All fuses look fine.
Any thoughts on what to check next?
