C2 1964 Door panels - NCRS Discussion Boards
C2 1964 Door panels
  • Dino L.
    • February 1, 1996
    • 694
    C2 1964 Door panels
    Can anyone describe to me the difference between a coupe and convertible door panel? Can they be interchanged, can you tell them apart?
    Dino Lanno
  • Richard T.
    • February 1, 1979
    • 858
    Re: C2 1964 Door panels
    The upper rear end of the coupe door panel has a curved cutout that fits around the rear coupe door frame. This area is straight on a convertible panel. I suppose that you could use a coupe panel on a convertible but it would be noticable. I don't think it would work the other way around though.
    • Dino L.
      • February 1, 1996
      • 694
      Rick, If you were trying to use a perfect set of original door panels from a coupe on a convertible, could you pull back the vinyl, and weld a piece of steel to replace the cutout, then reglue the vinyl assuming there was enough left, or are the window felts and rubber wipers also affected?
      Dino Lanno
      • Richard T.
        • February 1, 1979
        • 858
        Dino,
        I sent you an email. Rich
