C1, '58 LWR Radiator Baffle - NCRS Discussion Boards
  • Terry Leeker
    How is the lower radiator baffle joined to the lower valance; screws, rivets, adhesive, all of the above? My lower valance, having been previously replaced sans baffle, has no telltale attach points. I was hoping the PM part would have pilot holes or dimples - no such luck.
  • roy braatz
    Re: C1, '58 LWR Radiator Baffle
    Lower radiator support had a rubber thick seal held by four srews.If you mean radiator shield- shroud, it' the same as 55 to early 59.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Terry... Hope you have AIM and NCRS Judge Manual. Read those items and then lets revisit the issue if need be. DC
      • Terry Leeker
        To clarify, The LWR radiator baffle I am referring to is the fiberglass component that bridges the gap between the lower portion, forward edge, of the radiator support and the LWR front body valance. I suspect the porpose of the baffle was to better direct the air flow from the grill to the radiator and minimize the flow dumping beneath the radiator.
        • roy braatz
          Re: C1, '58 LWR Radiator Baffle "OH"! *NM*
