C3 Headlamp Switch problem - NCRS Discussion Boards
  • Ed Driscoll
    Hi Guys,
    I've just placed a replacement switch next to the original, and in the area marked "7" (on the side, pressed into the bakelite) there is no contact. Also, there is a ground contact on the bottom of the replaqcement switch that doesn't exist on the original. Anyone familiar with this? This is the replacement, so...
    Does anyone have a schematic of the switch? I'm flying blind. I'd replace the electrical side of the new switch with the old, but the new has an additional ground contact.
    Thanx
    Ed Driscoll
    Re: C3 Headlamp Switch problem
    Ed------
    I can tell you this much: the headlight switch for 1968-75 Corvettes changed over the years. Originally, it was GM #1995166. In June, 1975, the GM #1995166 switch was discontinued for PRODUCTION and SERVICE and replaced by GN #1995191. The latter switch has been the only SERVICE switch for 1968-75 models available in SERVICE ever since then and thousands of 68-75 Corvette owners have used them to successfully SERVICE their cars. I strongly suspect that the change was made to remedy a dimmer circuit problem for which the original switches are notorious. In fact, that may also closely relate to the elimination of the #7 terminal. Improvements to the internal configuration of the switch likely rendered it unnecessary.
    Also, I can tell you this too: I have an original GM #1995166 switch in my collection [NOT for sale]. If I were to need to replace my switch would I use it? Not a chance. I'd use one of my 1995191's [also not for sale] without the #7 terminal. I think this is a better switch. Might as well take advantage of improvements which occur over the years, especially for a component that absolutely can't be seen.
