A recently acquired '66 L72 car puzzles me with respect to clearances in the engine compartment. The clearance between the fan and the frame crossmember is about 1/16" at the closest point (the closest point is not directly at the bottom, but a little towards the passenger side). The clearance between the driver side exhaust manifold and the A-arm is almost zero - it looks like it has actually touched a few times (there are several alignment shims, but not excessive). The clearance between the bellhousing and the tunnel is about 1/8" on the upper driver side of the bellhousing. The clearance between the shift linkage and the top of the tunnel is almost zero.
Here are the specifics - the fan is original, the right part number, and the right diameter. The fan clutch is new and correct. Motor mounts are correct, non-locking, and appear to be in good shape. The bellhousing is original - the 444, specific to '66 only (I think the 444 is larger diameter than the '67 housing). The shifter linkage is in the standard long-throw position which positions it closer to the tunnel. The engine, trans, and bellhousing are the originals. The frame is original, not bent, car not wrecked, etc.
This trans/motor is stuffed in there, with no room to spare! My other '66 L72 has more clearance at the fan (3/4 to 1") and at the A-arm, which makes me think that on that car, the back end of the trans is "lower", which tips up the front of the engine, giving more clearance for the fan and the exhaust manifold at the A-arm. On the car with the tight clearances, it appears that if the tail end of the trans was lowered it would tip up the front of the engine, buying some fan and exhaust manifold clearance. It does NOT appear that "raising" the front of the engine via the front mounts could be done because that would drive the top of the bellhousing and the shift linkage into the tunnel.
Is there a procedure for "adjustment" of the trans mount to position the engine with the correct attitude (shims, etc.)? After comparing the two '66's and a few 67's, the 66's appear to be a tighter fit, probably due to the unique bellhousing. However, the difference between my two 66's leads me to believe that the motor mounts (possibly the trans mount in particular) are the root cause of the clearance differences. Any thoughts or similar experiences with 66's? 1/16" fan clearance can't be a good thing...
