L72 Spark Plug Gromment Order - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hello:
    I need some help on the correct order for the spark plugs wires where they pass through the spark plug gromment on the RH side of the sheilding.
    I found the LH order in the AIM.
    The LH side is:
    Top left - wire # 7
    Top right - wire # 3
    Bottom left wire # 1
    Bottom right - wire #5
    The AIM for the RH side is not clear. Could someone tell me the order for the RH side please.
    As usual, thank you for your help.
    Kurt
