C3 - Correct Valve Covers for 71 270hp - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    Can someone tell me if the pressed metal valve covers are correect for a late 71 with 350/270hp. What I can find they were painted on the engine and are orange. Just want to check.
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Dino L.
    • February 1, 1996
    • 694
    Re: C3 - Correct Valve Covers for 71 270hp
    My original late 71 270 hp car was stamped steel with orange paint
    Dino Lanno
      Dino and Ralph------
      Yes, that's what all 1971 270 hp were originally fitted with---stamped steel valve covers which were originally painted with the entire engine assembly.
      If you're in need of a set, go to a self-service type wrecking yard and look for any 1971 model with small block V-8 engine. 1969-70 or 72 will usually work, too, but small facets of configuration may be different for other years.
        • 11608
        Correct 1971 covers will have flat metal clips on the inside of the driver's side cover to retain the TCS wiring as it goes to the solenoid on the L front of the carb.
        Patrick
        • Edward McComas
          Don't forget about the push in oil plug, used on 71 and 72 covers, in place of the twist in oil cap.
            • 11608
            ...with the narrow width to the "OIL" letters, as opposed to the wider lettered plugs available OTC in any auto parts store in the USA.
            Patrick
              Patrick-----
              These rubber push-in oil plugs were a sad day in the annals of Chevrolet and Corvette engines. Thankfully, their use on small blocks was limited to 71-72. Their use on Corvette big blocks extended from 1971 through 1974. I like to forget that they ever existed. Truly, a completely bogus way for GM to save a few cents per engine.
                • 11608
                Joe,
                My car has the aluminum LT-1 style covers with the turn-in cap anyway.
                My originals are on a shelf under the "someday" category...as in "someday when I like leaky valve covers I'll reinstall them"
                Patrick
                  Patrick-----
                  The push-in style covers were used for LT-1s, too, for the 71-72 model years. In fact, in 1972, or so, when I cracked the 70-style twist-lock aluminum valve cover I had purchased for my 69 300 hp right after I got the car, I had to purchase one of these push-in style aluminum covers. At that time, they had replaced the twist-lock style for all SERVICE requirements. I "lived" with that miserable thing for many years, even though in about 1973, the twist-lock style cap replaced the push-in for evermore. I never sold it, though, since I don't sell parts. It remains as an historical, but despised, artifact in my collection.
