C2 Glove Box Door Scratches - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    Does anyone know of a procedure to remove scratches from the brushed aluminum insert on the glove box door? I'd like to try removing these scratches before I decide to rebuild the door.
    Dave Kitch
    33108
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 Glove Box Door Scratches
    Dave,
    In order to fix the scratches to any acceptable job will require the disassembly of the door. You need to be able to work on the seperate aluminum sheet metal part or replace it.
