69 restoration questions - NCRS Discussion Boards
  • kelly theaker
    -the 2 thermostat bolts on the intake should have what head mark?
    -the 1 bolt on the distributor hold down should have what head mark?
    -the throttle linkages for front and rear carbs, which linkage goes where? short or long?
    - and looking at the Paragon book they state that a small tang is used to hold the spring for throttle return , i do not have this , but the bracket thsat holds throotle cable does have a hole in it . Am i missing the tang or did this early 69 just use the hole provided on the bracket ?
    - the door ajar switch, rivets ,the one adjacent to the quarters, was this bracket installed before paint or after?
    Password:
    [ Post Response ] [ Read Prev Msg ] [ Read Next Msg ]
    NCRS Technical Discussion Board is maintained by John Waggoner with WebBBS 5.12.
  • Jeffrey S.
    • May 31, 1988
    • 1879
    Re: 69 restoration questions
    Kelly
    I will look at my 69 tomorrow and give you the answer to the head marking questions you asked. I can't help you with the carb/spring/bracket questions since my car is a smal block. The fasteners are all original so I can help you there.
    Jeff Salz
      • 15573
      Re: 69 restoration questions *TL*
      The thermostat bolts will likely be different for Big Block and Small Block, and there is a chance that the distributor hold down bolt may have a different headmark as well. Best to look at like engines, and a lot of them, for headmarks.
      There may have been many headmarks used in the same application. Chevrolet put their fasteners out for bid, and the supplier changed from time to time. The best you will get is a list of several likely headmarks for each position. This has been covered here in other threads in the past.
      • kelly theaker
        thanks for the time spent , much appreciated.
        • kelly theaker
          thanks terry, any answers on the spring hold down , for tri power?
            • 15573
            • kelly theaker
              Thanks again Terry, i wish i could get some other members involved here , possibly 435/ owners , they must be pollishing and driving.much better than driving this mouse on desk. I will see what comes up this week , maybe some rain ?Thanks again
              • Rich Grant
                Kelly
                Send me an email if you have any specific questions on your car and I'll take a look at mine. I have a very late 69 435hp convertible, which might or might not be helpful to you. As far as references, try the Judging manual for 68-69, I've found it to be very helpful in reserching my car. The carb springs are different depending on when your car was build, the manual explains it very well. Also, I've found Paragon to be a good resource when it comes to bolt patterns. Take a look at their website.
                Rich
