I am having problems with the high idle being set when the choke is used. The choke rod or choke thermostat is wrong. I purchased a choke rod from C.Central and a thermostat from NAPA.
The choke flap on the 3247 Holley will not completly close and the high idle cam setting will not work. Can I bend the choke rod or stretch the thermostat to allow the choke flap to completely close and to set the high idle?
When warm the car starts very easy. When the car is hot, I need to depress the gas pedal similar to a flooded carb. Could my floats be too high? I have them set just below the screw holes.
Thanks John!
Thanks John!
