Hi
Can anybody tell me which posts the wire connector for the temp gauge goes on?
I can't seem to get my temp gauge to work. I have put 2 gauges in and niether have worked. If your looking at the back of the gauge there are 4 post. 12 o'clock, 3 o'clock, 6 o'clock and 9 o'clock. which post does the power wire go on and which post does the green wire to the sender go on?
The reason I don't know is someone put in a aftermarket gauge and it did not require any power. so the connector was still there but nothing else i have picked up the tabs and insulators i need but i can't seem to get it to work.
What i have so far is (with the power wire on 3 o'clock and sender wire on 9 o'clock) 13 volts at the sender with the gauge in the circuit. I have (with power off) 750 ohms thru sender cold and 150 thru sender with car warmed but not hot i'd say 160 deg. i have 100 ohms of res thru gauge with wires disconnected. if i remove the sender from circuit and place wire to ground it still won't move the gauge (either of them).
Do I have the wires on the wrong post?
I ask questions before about this gauge problem and i want to thank everybody who helped with answers but i still haven't got it to work yet.
any help would be appreaciated
thanks
mike
thanks
mike
