C2 (63) Steering assembly installation - NCRS Discussion Boards
  • Gary Cederman
  • Kenneth S.
    • July 31, 1981
    • 302
    Re: C2 (63) Steering assembly installation
    The steering column is adjustable in and out so the amount of column showing in the engine compartment is a factor of where you end up adjusting the steering wheel. When I installed mine, with everything loose, I sat in the drivers seat and moved the steering column & wheel back and forth until I got it where it was comfortable and then tightened everything down.
    • Gary Cederman
      Ken,
      Thanks for the response.
      Last night I made some measurements and noticed that there is a spec. on how far the housing for the directional signal was to be from the housing that is attached the the steering wheel (0.070 to 0.090 inches). So, from there, I was able to calculate some measurements down to the steering gear.
      That should get me close and I am planning on attaching everything but leaving the bolts loose so that I can do what you suggested.
      Thank again,
      Gary
