SHOCKING !!!! - NCRS Discussion Boards
SHOCKING !!!!
  • Jerry G.
    • April 1, 1985
    • 1022
    SHOCKING !!!!
    Help! I'm, in Atlanta at the Walter Mitty Vintage race and I have an electical problem. My system doesn't seem to be keeping a charge. The voltage at my altenator is 12.8 Volts. Is this enough to charge the battery? It's a single wire DELCO alternator. I'd appreciate any advice from you sparkies out there . Jerry I'm at DNIK@AOL.com
  • Craig S.
    • June 30, 1997
    • 2471
    Re: SHOCKING !!!!
    Jerry - sounds like you have either an alternator output problem, regulator problem, or wiring problem. You should see somewhere around 13.8 to 14.5 volts at the alternator output terminal. Since you indicate single wire, I am assuming you have a 10DN series alternator and external regulator, so I would start at the regulator first....Craig
    • Jerry G.
      • April 1, 1985
      • 1022
      ReThankyou *NM*
      • Jerry G.
        • April 1, 1985
        • 1022
        It worked! I came in third!! A podium finnish!!!
        It was an all Chevrolet finish. A Camaro in first and Corvettes in second and third. Jerry
