I have a May 67 built SB. I located a used fan shroud. It is in good condition but the color is a medium gray with black paint, not a dark gray like the Judging Manual says it should be. It also has one flat head rivit on the upper driver's side. Is this correct for my car? If not, what is the correct application for it?
67 SB fan shroud color
Re: 67 SB fan shroud color
I have purchased years ago a shroud or should I say the 3 pieces from GM that get glued together. Two of the pieces are a dark grey to almost black as should be on original cars. The third piece is a light to medium grey. Possibly the shroud you have was purchased in pieces from GM as I did and they put together incorrectly. I still hae the pieces but never used them as the color of the third piece is incorrect. Possibly Joe Lucia can help here.1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
1969 L71 LeMans Blue, Bright Blue Convertible
1970 L46 Monza Red, Light Saddle Convertible - Duntov
1976 L82 Classic White, Firethorn
2013 LS7 Black, Ebony, Convertible
Moved on -
2006 LS2 Black, Ebony, Convertible- Top
