Removing the vent from the diff. cover - NCRS Discussion Boards
  • Tom Sarno
    Is there an easy or right way to remove and reinstall the vent from a differential cover.
    Tom S
    Re: Removing the vent from the diff. cover
    Tom------
    It's a very light interference fit in the cover. You simply pull it off by holding it from the tube portion (not the cap). To reinstall, simply tap it in lightly.
    • Tom Sarno
      Thanks Joe
      Just wanted to make sure, with the way my luck has been going it break off and then I would relize there was a trick such as push then twist, or say the majic word first.
      Tom
