I have recently rebuilt the brake system on my 1960. All four wheels are shoes, no discs. I replaced the shoes, cylinders/slaves, hardware, lines, transfere blocks...everything up to the master cylinder. The master cylinder was really in pretty good shape (I thought), so I bought a rebuild kit, honed the inside of the chamber, replaced all the springs and seals and put it back together...being careful not to take too much off of the cyllinder with the hone.
Replaced the fluid, bled the brakes and all seemed to be working well, no leaks, etc. When I took the car on the road, the brakes are like MOOSH...worse than before the rebuild (before the rebuild, I had several cylinders/slaves on a couple of the wheels that were frozen due to corrosion). I get some stopping, but need to pump the brakes several times, need to take the pedal all the way to the floor, and they seem to fade. I am assuming that it is the master cylinder, but wanted some input. Does this sound like something/some seal is installed wrong and leaking back....reason for fade and poor pressure? Do I need a new master cylinder? Have it "professionally" rebuilt?
Also, I had a pull to the right front side before I rebuilt the brake system...was told that was likely a poor functioning cylinder on the left front that made the right front seem to grab so much in comparison....if you had seen the wheel cylinders, you would have believed that. However, with the new lines, cylinders, shoes, etc, I still feel it pullling to the right up front...thought that even with poor pressure, I would at least now be having "even" pressure !!! Any ideas about the cause of that???
Thanks in advance for your input and suggestions.
Rick Krason
Rick Krason
