My 71 sb seems to have a gassy odor coming from the air openings in the dual air snorkel. After I drive the the car and park it in the garage, I have to leave the door up for a while so the garage doesn't smell too bad. I have checked all the fuel lines and the fuel pump doesn't leak nor the gas tank. I have it down to the carb. And it isn't leaking where the fuel line goes in to the carb. As I said, after about thirty to forty minutes the strong smell of gas is gone, but you can still smell it from the snorkel. The carb was rebuilt about three years ago, but I don't really know by who because I bought it from a major corvette supplier and they had it rebuilt for me, but I am a little suspect on his abilities. The nightmare story behind all the problems I had getting it would make it seem that I bought it from the "Three Stooges". And that would be demeaning them. I know that the car will get the hottest after you turn the motor off and it would vaporize the remaining fuel in the carb, but I can't think that much smell is normal. Is it? It seems to run o.k. I have a 3:36 rearend and it is a auto, the original motor was rebuilt three years ago and gets 13.5 to 14 mpg a 65 - 70 mph. Is that normal? The carb is properly torked down on the intake and it has the proper mounting gasket. All the C.E.C. and pollution equipment is hooked up and working. That leaves me to think I need a new rebuild on the carb. I know this is long but before I send it off, I thought I would try to give you all the most info I can.
Thanks for anyhelp you can give me,
Chas
Chas
