I need help or advice on the removal of the springs in the posi unit on my 64. One of the cages that hold the clutch packs lost two of the legs, one of which found it's way between the pinion and the toe of the ring gear, chipping about a half inch chunk out of the toe of a tooth on the ring. I've located a new cage, but I can't find anyone in my community that has the Kent Moore tool J-21175-4 that's shown in the service manual, which is required to remove the springs that preload the posi unit. I can't find a tool that might substitute, and I've tried to fabricate a tool, but the mild steel that I'm using gives under the pressure of the spring.
I'm sure others have come across this problem, and I'm wondering if there is any other solution than sending the entire unit to a specialty shop. I've been to the local drive line and transmission shops and all of the GM dealers in my area and no one has had any experieance whith this Dana unit.
Any help in this matter would be greatly appreciated. Thanks, Phil
