I am replacing the heater hoses on my 66 small block and will use the OEM type spring clamps. My concern is leakage. Is there a sealer ( not adhesive) that can be used to prevent leaks?
Also according to my AIM manual C60 D3 a screw type hose clamp at the water pump connection is used. Correct?
