C-1 4 Speed - NCRS Discussion Boards
C-1 4 Speed
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 4 Speed
    I just got my BW T-10 gone thru and I was having trouble shifting into 2nd and sometimes third. New 2nd and 3rd gears were installed before the problem. Put in new shift forks. I am now wondering if I have the correct clutch fork and clutch adjusting shaft and one of them is causing the problem. I checked clutch and throw bearing and they are the right ones and working OK. HELP Thanks 1960
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: C-1 4 Speed
    Have you adjusted the shift linkage? Could be that rather than an internal problem.
    • William C.
      • May 31, 1975
      • 6037
      Re: C-1 4 Speed
      If upshifting is a problem, it is less likely that the clutch system is at fault. If the clutch is dragging, downshifts will be more difficult.
      Bill Clupper #618
