All,
My first question is that I had a new clutch installed in my '71. 1 - 4 is good without any problems. When I try to place it in reverse, I have to grind it in. I was told that Munchie trans will do that until the clutch is worn in. Is that true ?
Next problem, is that now that the clutch is new, I keep blowing a fuse that controls the windows, turn signals, rev lights. Is there a ground wire or hot feed that I could have put back wrong on the starter ?
Thanks Greatly
Paul Gordon Tri-State Pitt's '71
Thanks Greatly
