I have a real mystery problem with my car. Several Corvette guys, mechanics, and I have looked at my car and just can't figure this one out. It is a 71 small block with factory air. I have mentioned this in a previous post on the CorvetteForum.Com (http://forums.corvetteforum.com/zerothread?id=545391). From what I can see in the factory assembly manual and from looking at pictures in vendor catalogs, the A/C brackets look correct in size, shape, and appearance. Issue: The bracket that mounts to the exhaust manifold is supposed to align with bracket that mounts to the water pump but they don't. Where they come together, the compressor bracket is supposed to align with them both and serves as the forward mounting point (and hinge) for compressor mounting and adjustment. A bolt goes through the three to form the hinge point and mount and, additionally, this bolt head secures the small steel brace that secures the heater hoses and keeps them away from the A/C compressor. I hope I haven't confused you.
The problem is, there is about a half inch difference in alignment between the exhaust manifold and water pump brackets. It is impossible to get them to align as there are no adjustments and the parts can only be installed one way. The brackets have been installed with the correct hardware in accordance with the factory assembley manual. Since the bolts in the brackets attach to bolts holes in the block, I can't see where there can be an alignment problem there. The only thing I can seem to come up with is the possibility that one of the brackets may be a replacement part that is wrong. The exhaust manifold is a correct matching number part and the water pump is a Stewart Stage 1 pump.
Have any of you ever had this problem or heard of it. If so, what resolved the issue? I wish I had absolutely correct brackets to compare mine too. Do any of you have them laying around that I could make reference to? I will pay for shipping to and from your residence if I can borrow them for the comparison check.
Mystified in Tennessee (Rick)
