OK I’m convinced I can use the 58 nonposi axles with a posi carrier. But let me add a few comments.
Jim,
Your retrofitting a posi in your 56 was explained in an article in the Restorer that discussed installing a posi unit in a 55 or 56 Chevy or a 56 Vette. This installation required either reducing the length of the axle shafts by an 1/8” or installing the 3743035/3743036 axles (which ARE an 1/8” shorter than the 55/56 axles).
I’ve refined the table from my first discussion thread and isolated 58 Vette
rear axle data from my April 1960 GM parts manual.
58 Vette Axle Shafts (Group 5.420)
Non Posi.
part# (L)3741827 (R)3741828.
left: 28 9/16” right: 30 1/16”
Total length of non posi axles:
(58 5/8”) – banjo width (55”) – bearing width (1 3/4”) = 1 7/8”.
Posi.
part# (L)3743035 (R)3743036.
left: 28 7/16” right: 29 15/16”
Total length of posi axles:
(58 3/8”) – banjo width (55”) – bearing width (1 3/4”) = 1 5/8”.
58 Vette Axle Shaft Bearings (Group 5.855)
part #HY JRN1542 WAB-23 or #ND-RW607SY12.
bearing width = 7/8” (I measured the bearings on my 58 nonposi axles)
58 Vette Axle Shaft Bearing Retainer (Group 5.816)
part #3739104.
ACCORDING TO THE GM PARTS MANUAL, 58 Vette posi and nonposi
rear axles call for the same axle shaft bearings (part #HY JRN1542 WAB-23
or #ND-RW607SY12) and axle shaft bearing retainers (part #3739104).
The width (measured from axle tube flange to axle tube flange) of all 56-62 Vette axle housings (banjos) is 55”.
Based on the parts manual data, I don’t understand how a posi unit can be
assembled into a nonposi 58 banjo using the longer nonposi axle shafts. The ¼”
difference between the posi(1 5/8”) and nonposi(1 7/8”) axles has to be due to
dimensional differences in either;
(1) the depth of the axle shaft bearing retainer flanges in the banjo or
(2) the width of the differential case (where the axle shaft flutes engage
the side gears,
(3) OR BOTH.
Again, my initial concern is using the longer nonposi axle shafts with a posi carrier will bind the ends of the axle shaft against the differential pinion gear shaft. I believe the shorter axles prevent this from happening and that’s why the General offered shorter axles.
Roy, for the sake of educating me, can you be specific as to what the differences are?
Jim,
Non Posi.
Posi.
part #3739104.
the side gears,
(3) OR BOTH.
